I just had to get this off my chest. Why? Cause it's the internet, and you don't have to hear me wanting to scream on the inside at the utter FAIL of the human race.
So, buddy of mine and I were talking. He is a builder of old V8's and my age. I'm 23, just to clear that up. OK! So we get to talking cause he's wanting to toy with the idea of turboing an older camaro he's got. I think it's a 91 with the the trottle body injection. So we're toying with exhaust manifold designs. He can't get past the N/A mindset that longer runners mean a more even pulse, thus better exhaust scavenging, and therefore better breathing engine. Now my own research has found that a turbo motor is DRASTICALLY different in exhaust design than a NA Exhaust. WHY!? Cause of BOOOOOOOOSSSSSSHHHHTTT!!! A turbo manifold should be set up with the shortest length runners possible. WHY? To spool the turbo of course! Funny thing about turbos...since you're forcing air through it, the nice long equal length runners will prove to be less than effective when compared to some nice equal length short runners. Do I preach equal length!? OH YES, pulse rate is still factor, but we're not scavenging exhaust gasses...cause there's gonna be back pressure before the turbo anyway...So where do we want the exhaust to breath? AFTER THE TURBO!! Why? Let's break it down.
1st action, push accelerator.
2nd action, motor begins to turn faster, thus creating positive pressure in the exhaust stream
3rd action, positive pressure moves from area of a high concentration to an area of lower concentration via this lovely little principle of air pressures derived by Sir Isaac Newton in the 1860's.
4th action, pressure differences in the exhaust causes the high pressure gasses inside the manifold, to move to a lower pressure described previously, across a turbine. Thus spinning said turbine.
5th action, Turbine acts as a wind break. It creates a barrier in which the motor must now overcome. Granted we have bearings and the sort to ease the work the motor must do to create enough positive pressure to turn said turbine, but none-the-less...there is air resistance there!!
6th action, after air moves across turbine, it is hot and STILL EXPANDING. So we open the exhaust as wide as possible AFTER the turbo.
7th action, due to the much higher exhaust flow AFTER the turbo, and a lower exhaust flow/higher pressure gradient BEFORE the turbo, we can kinda create a scavenging effect that would be LOST if there had been longer runners before the turbo.
SO, in short...
Short equal length runners before a turbo means a very quick buildup of hot exhaust gasses. This lends itself better to a faster spool. A wide pipe located AFTER the turbo give the turbine a nice place to DUMP these hot and STILL expanding exhaust gasses. So we need this wider pipe to reduce the backpressure AGAINST the spinning turbine on the EXHAUST side, not the manifold side. So this hot, lower pressure, and STILL expanding gas has somewhere to um...expand. So say...a 3" downpipe. Then a 2.5" exhaust piping afterwards. What this will do, is allow these hot exhaust gasses plenty of room to to continue out the back of the car. SO, as the hot gas leaves the manifold, it flows across a turbine, into a much wider area, and lower pressure gradient....it expands, and continues down the exhaust tube. This rapid expansion due to the sudden pressure drop will actually CREATE a scavenging effect, thus kinda PULLING hot gasses from the turbo, and the nice 2.5" exhaust pipe allows these hot gasses to flow freely without backpressure, once the gasses have expanded and cooled (albeit only slightly) in the downpipe.
This means that long runner before the turbo are not needed. All your doing is creating MORE pipe that the motor MUST FILL before the turbo can spool. Meaning that there will be MORE LAG. So...why not set up your exhaust accordingly so that when you stomp it, your turbo just spools right up, and the exhaust can breath, motor can breath (correctly), and power can be made....QUICKLY.
...end rant.
SO, in short...
...end rant.
