Installshield 2
Gothenburg Superiority
Gen1GT said:I've always said that a nice long power band and average horsepower are what accelerates you. My speaking of a car with more horsepower will always out accelerate a car with more torque is a complete generalization, but it still pretty much holds true. You can't use the BMW as an example, because it still has more horsepower than torque, although your point of a massive powerband is correct. Although the race between the BMW and RX-8 would be completely driver dependant.
Horsepower is a generic term to describe torque/time regardless of gearing. It's what allows us to compare one car to another. You can't compare one car's torque rating to another's without knowing the RPM it occurs at and what the gearing is, which is way too complicated. And you're right of course, peak power doesn't mean squat. But I still hold strong on the point that making torque twice as fast is just as good as making twice the torque. And there are so many examples of cars with more horsepower that will out accelerate a car with more torque. And to make more torque, you just need shorter gearing.
You are right...there are pretty much no examples of real driven cars that illustrate what I was pointing out...but I just wanted the math behind it to be known...
So take for example the first cars we mentioned...one has 200hp and 100 lb/ft of torque....the other has 200lb/ft and 100hp...Now concerning their power curves, which is where it gets wildly theoretical...if you declare that each curve is equal in area, yet oscillated about the y(power/torque) axis...meaning the curves peak at a mirrored time in rpm...you mathmatically have an engine that can do an equal amount of work at accelerating a car...but it would take different gearing for each of the two curves in order to do that work in the same time interval (production efficiency)...
which is why I pointed out that it was theoretical, yet still not exactly true that hp is the only important part...but the reality is what you are talking about...you can't build two mirrored power curves like that...So its pretty much just a theory..
