I'm all about inexpensive, DIY mods to cars. I have several < $20 performance mods I've done, but I'm going to start with this one, which is mostly free.
First off, this was the best spot to pry from because it had the most pliable spot to stick my screwdriver in without marking:
the rest pops right off. here is how it looks :
Lots of plastic, but a very solid steel base. See those top 2 nuts? They're the top connection for the gear shifter.
There is quite a bit of play in them :
There are 3 ways to deal with this, 1 - Replace the rubber bushing with machined bushings to cut down on movement, 2 - pull the rubber out, add washers, call it good enough, or 3 - crush the rubber by tightening the crap out of it and hope it makes a difference.
I didn't have time to expose the lower connection point, so I went with #3. I torqued the nuts back on to 20 ft-lbs -- ended up being pretty damn tight.
The difference is incredible. I've always liked "feeling" the gears, and having some sense of what is going on, instead of just jamming it into gear. You get more feedback, and the whole assembly feels more precise.
Which brings me to mod #2 - The shift knob. I bought one of these:
https://www.ebay.com (commissions earned)
I offered the seller $20, and they took it. The knob is smooth, which is odd, but roughly 40% of the weight. This is personal preference -- I've never liked heavy shift knobs, I don't want to lose any feeling. This knob made a big difference for me, to get a rough idea of what it is like, try driving without a knob at all.
In summary, for less than 15 minutes and $20, my 2 went from limp noodle to precise shifter.
