Bit lengthy but wanted to give as much info as possible.
I have an 06 MS6 GT. ~85k miles. Recently I have had to give some gas in order for the car to turn over, witout hitting the pedal it just keeps cranking but no go. Used to be that I could just turn the key and car would start. I shouldn't have to give it gas for it to start so i don't know what the issue is. Car seems to be idling a bit rough lately too.
I did replace the rear diff mount recently and went with poly-urethance bushing but I seriously doubt that has anything to do with it. Don't think its the spark plugs because i changed all 4 at around 60k. I keep up with regular maintanace. You could consider me a "spirited" driver so it my driving that is causing problems or is this car just plagued with issues??
Car will lose power sometimes too when i floor it to pass a car. Here a strange sound mid to rear of chasis, nothing crazy but enough to make me want to ease of of the gas pedal.
CEL is currently on with an Exhaust Gas Recirculatory Valve code as well as a multiple misfire code.
Wondering if it could be a MAF sensor, O2 sensor, or maybe need to replace EGR.
Any Ideas... Thanks in advance.
MODS: AEM cold air intake, manga flow dual exhaust (cat-back).
