I recently bought an MSP with a supposedly blown engine so I could learn to do an engine swap. I know a good deal about these cars but I am not a mechanic and I am pushing the boundaries of my knowledge with this. I took the old engine out which recently had a new head put on, but supposedly 100 miles after that it lost all its oil and wouldn't rev over 3k rpm. The previous owner's mechanic told them it need a whole new engine and they sold it to me in that condition.
I picked up a used MSP engine from a forum member here and installed it this weekend, but it wouldn't start. Turns out it has very bad compression and when I pulled the valve cover I saw coolant mixed in the oil. I guess there is a major problem with my replacement. The guy I bought it from said he'd give me my money back if it didn't work so hopefully I am just out a little more time here (hopefully....)
At this point, I am trying to figure out my best course of action. I can pull the head on the replacement in the car currently and see if the gasket is blown, but is there any other common cause of coolant getting into the oil like that? I am praying the block is not warped. I also have the almost brand new head from the old "bad" engine and it looks fine, and I also do not see any damage to the cylinders or cylinder walls on the block. I honestly do not know what is wrong with this engine. Could it still have a bad bearing or some other part that might be easily replaced? Could it still be damaged and I just don't know how to recognize it because I need to know what to look for? I'm just looking for some advice from people with more experience. I'd love not to pull the engine out again if possible. Thanks for the help and let me know if there is any other info or pictures I can provide
