I'm running the Honda manual transmission fluid intended for the Si's from 06-10. I've had no issues.... Then again I've only used it for about 3500 miles and will change it every other oil change.What is the best trans fluid for the msp trans?
Ive been looking around with not much luck..
People throw a few brands out there GM Syncromesh Redline And some ford motocraft fliud.
Anyone have input on this?
For sure its not as heavy as the protege stuff but the Si's starting in 2006 came with helical lsd's similar to the ones on the MSP. That's why I feel comfortable running it.Most older honda transmissions require 10-40 motor oil. Not sure about the new ones but I'm sure they don't need as heavy as a weight the protege does
Pull the intake tubing off and gently jiggle the wheel in the turbo to make sure there's no shaft play in the turbo. Then remove cold piping to check for oil.
Don't be afraid to run the car hard on test drive this will show any issues it has. If seller does not let you he is hiding something. When the car is off turn key to on position to make sure oil, check engine, abs, and srs lights come on before starting. If they don't they have probly been removed. Make sure it has set for ~8 hours before starting up to make sure valve seals are good and no lifter tick. Pull the oil cap off and make sure engine looks clean and it's not black and gunked up.pull radiator cap off ( when it's cold) and check for stop leak. Check oil for cleanness and metal. Check brakes and tires. Also give wire harness a thorough look over to make sure it hasn't been hacked up. Any mounting brackets that are not the same color indicate being replaced from rust or a wreck ( regardless of what car fax says) check all body lines to make sure they are even and don't have oddly spaced gaps which is another indicator of an accident. Make sure ac blows cold even though it's winter. Take it too a local inspection place and ask them to do a state look over with out replacing the sticker.
I've been burned in a few cars and have a good check list now. There will always be small things here and there that you will find wrong
If I was selling a legitimate car and not trying to rip someone off I would help them pull the intake piping off...
That's the risk you take buying a used car. Especially one that is 10+ years old and not known for reliability.
I'm just saying that a buyer shouldn't expect to be allowed to start removing parts from a car to check things out. If a particular seller will allow it then go for it. Just don't expect it or automatically assume something is wrong just because they don't. It isn't normal even for an auto enthusiast much less your average person. You have to keep in mind that the average auto owner has never changed his own oil and wouldn't even know where to start. He certainly isn't going to let you start taking things apart.
