Just be sure you get one for the correct engine and trans and you should be OK. If you have an auto, make sure it's for an auto, if you have the 2.0L FS motor, be sure you get one from an FS 2.0. Be sure you don't get an Mazdaspeed ECU unless you have a turbo on the car or it will not run properly.
