I have a 98 Protege 1.5 engine with a broken pass. side motor mount. I haven't taken it off yet but after fondling it yesterday their seems to be a steel plate with a hole in it on the bottom of the mount. The mounting bolt on top broke out of the rubber an left a divot in the rubber about 1/2 in. deep. My plan is to remove the motor mount an drill a 7/16 hole all the way thru the rubber, then use a 7/16 cylinder head bolt an put it into the drilled hole, then fill in the divot with window weld. I'm also going to tack weld some beads to the side of the bolt to help keep it from turning inside the hole. I don't know how well this is going to work, I still need to take it off. So what do you think, maybe, maybe not.
