I recently purchased a 2002 Protege5. The car runs and drives great but the headlights, turn signals, horn, and cruise don't work. I really don't care about the horn and cruise. I need headlights and turn signals. My tail lights and brake lights work. The previous owner tried to install his head lights and hacked the wiring up pretty bad. I have pieced the headlight wiring back together and still no headlights?? As for the turn signals.. They don't do anything, I can use the turn signal switch or the hazard button I get nothing. I get power to the turn signal relay when use turn signal left or right but no power to relay when hazard button depressed. Arrows in dash do not light up. I have went over the wiring diagram and chased wires for the last couple days. The only thing I can find wrong is the ground wires coming out of the harness that runs from under dash to the fusebox under the hood are grounded to the driver side of the engine bay just beside where the harness comes thru the driver side fender instead of running down to the ground point under the driver headlight. (4or5 black wires). I am at a loss, its driving me crazy that I can't figure it out. I know I am over looking something but I can't figure out what.
..also I know where there is a harness from a protege 4 door(from fuse box to under dash) I know that the protege sedan has one dual element bulb for each side and the protege5 has a separate bulb for low and hi but other than the headlights would it switch out and work? Since Im not getting power thru the harness I think that might be part of it? Idk?
Any ideas would help
PS. My blinker fluid is full
