mutiny5050
- Protege 5
I recently blew my head gasket on my 2003 P5 due to a cracked radiator. I have since replaced the gasket and radiator and in the process of taking everything off I took off the camshaft and pulleys . I figured there would be a proper way of setting the alignment and I followed the how to guides to the T. Unfortunately the car does not start or kick, it just cranks over. When taking out the spark plug there is gas in the cylinders. I am being told they are 180 degrees off. Not sure how this happened as I was TDC on Cylinder 1 and all marks aligned. Is this the case or something more serious. Here is a Pick of TDC Cylinder #1 closest to the pick with all markings aligned. Any thoughts?
