So [I am ashamed to say] I have a 95 1.5 auto protege and it's developed the random downshift issue as expressed by Mazda:
Luckily they don't say where the clip is and I can't find it. Currently I am driving the car with all transmission sensors and ECU unplugged which gives me first and second gear manually. This is less than optimal. Anyone know where the short is? I have better things to do than tear through the entire wiring harness looking for it so if no one knows I'll just set this pile on fire and call it a day.
I didn't see anything from a search through a few hundred posts.
mazda said:1997 MAZDA PROTEGE TSB 01098 Details
Bulletin #: 01098
Sequence #: 6092410
Date: 10/14/1998
Component Name: 103100 power train:automatic transmission:control module (tcm, pcm)
Make: Mazda
Model: Protege
Summary: Some vehicles may exhibit erratic shifting, o/d off indicator light flashing with malfunction indicator lamp on as a result of the valve body harness (transaxle fluid temperature sensor circuit) being pinched by a metal clip which is attach
