steelhead11
- 2002 Mazda 626
Mazda 626 RPM Drops from 750 to 500 RPM when heat is turned on
Hi,
Thanks for having me!
I have a 2002 626 4 cylinder and I'm having an issue.
With the car running, I'm reading 14.5 volts across the battery with no load and no issues. When I turn on the heater on, every 5 seconds the car dips to 500 RPM for a split second and jumps back to 750 RPM while the voltage drops to 13.5 and back to 14.5.
I had the charging system checked and it appears to be fine.
Any information would be appreciated.
Thank you
Hi,
Thank you
