I've had my MSP for about a year, just starting to put work into it. Car has no stutter, idle, or other issues.
Installed an Autometer Autolite II boost gauge. I installed the vacuum T inline between the IM and the brake booster, before the one way check valve.
Car holds a steady 22-24 pounds of vacuum.
NOW the issue I am having is the car only boosts to about 4-4.5 lbs when under load.
I was under the assumption the car should push slightly higher numbers than that with a factory set-up.
I am about to install my FMIC, hard pipes, and BOV so I want to make sure everything is running correctly before I do everything.
