raul_gianino
- 2003 Mazda Protege5
Today I changed my front driver axle. After I finished I went to drive it and make sure it was all nice. When making turns to a certain degree there was a constant thumping. Came back home took off the wheel and everything seemed to be tight and in place. I jacked up the front two wheels off the air, turned on the car, and let it roll on 1 gear. The passenger wheel was spinning, however the driver side was barely moving and if it did move, it was on the constant struggle to slow down and stop. I was able to stop it with my hand. Something is obviously not right here. Could it be a torque distributor in the tranny ? Has anyone had this issue ?
Thanks
Sent from my iPhone using Tapatalk
Thanks
