I made an attempt at removing the front struts on my Mazda 5 (to replace) following instructions for the 3. But I can't push the lower control arm low enough to disengage the strut. It is clearly loose, but it seems that I need a inch or so more travel in the suspension. I'm hoping that it isn't necessary to remove the drive axle. The axle nut is a large special nut (26mm or so).
TIA.
TIA.
