I replaces my plenum gasket which I have did in the past it pretty easy and even this time I took my time enjoying my self. I had to remove a broken bolt with my welder yes the battery lead where undone.. I clean the intake runner and etc. I checked all connections to each sensor I had to undo checked engine fuse and all fuses. I had everything together and it was time to fire in the hole well this time it just cranked and cranked. I had no spark . What get me I never even touch the coil so I replace it and the crank shaft sensor and still no spark. I have battery volts to coil 12.15V but no pulse volts when cranking with tester. With the connector unplugged green wire battery volts no volt on any other wires . I think I read some where the black wire should Have volt also maybe the pin on the Coontor it broke . anyone have any tip what to look for?
