P0660 - Most likely your VICS vacuum switching (solenoid) valve. Easy and cheap fix. Get two of them as the same part is used for the VTCS solenoid and the PRC solenoid, and these fail fairly regularly.
P1250 - Pressure Regulator Control. I can't remember where this is located.
Replace those two parts, clear your codes, and you are most likely good to go.
