hornsfan10609
Certified Mazda Tech
- 2003.5 Mazdaspeed Protege x2
Some short self tappers? You may have to get a JY gas tank if it comes down to it, but I bet you can make it work with some new screws/bolts.
That sounds even better, you may have to drop the tank if you really want to ensure no shavings get in there.So instead of using the OEM screw holes, rotate the flange so I'm in the middle of the OEM holes, then use short self tapping screws? I'd worry about getting metal into the tank, but I could run the shop vac next to where I'm drilling (or cover tank with a towel). Is that where you're going with that idea? If so, I like the sound of it.
