CopenGrizz01
- 2000 mazda protege lx 1.6l
i have a 2000 mazda protege lx 1.6l
so it threw a cylinder 2 misfire code so i replaced plugs wires. but it still kept popping up. so i did some searching and was suggested to move the cylinder 2 injector to a different port. i did this and the injectors are leaking from the bottom. so i took the rail back off and moved the injectors back to the ports they were originally on, but they are still leaking like crazy. im not sure what im doing wrong. i tightened the rail down as much as possible, didnt forget to put anything on such as the plastic spacers under the rail mounts. im thinking maybe the seals are toast but they looked fine and if they were bad they would have been leaking before i removed them i would think. as soon as i start it up they start spraying fuel everywhere from the bottom of the injectors. thanks for any help, hopefully this is the right forum i should be posting in.
