fan only works on 4
pdx-tony
03 P5
I have seen the posts about ac not working on 1,2&3 but my heater fan only works on 4 at which point the ac light goes off. Is it probably just the fan switch? I got the car in the summertime and I don't really use ac unless it's super hot outside so I didn't notice the problem for a while.
It's not that my ac doesn't work it's the fan it's self that won't work on settings 1,2, and 4 on 4 it Works but no ac
Resister us behind the glove box in the bottom of the blower motor. Pull it out I could see the broken wire traces in mine.
Resister setting 4,is straight 12volts all other motor setting use a blower resister.
That did the trick, replaced it today now all speeds work and ac works on all 4 now thanks I almost replaced the switch that would have been $38 but I got the resister for $35 and that's much easier to replace
