CX-5 Parking brake leak to ground error code
I am getting a left side leak to ground error code for the electronic parking brake of a 2016 Mazda cx5, does anyone know where to locate the wiring harness and possible issues? Thx
your car may be subject to a rcall for the EPB. check your vin here
Checked our VIN, with thanks for your reply.
Our car is clear of any recalls. Thx.
Still trying to isolate this short to ground in the wiring.
The wiring harness connects to the EPB motor that is on the back side of the caliper. The issue could be a bad EPB motor (speculation, no first hand experience). You could try disconnecting the harness at the EPB motor and seeing if that changes the error code. Ideally you would have access to the factory repair manual as it would likely have troubleshooting sequences for EPB errors. You may find something useful in the manuals that are mentioned in this thread.
