I was going to turbo charge by P5 but never did so I am selling my forged internals. these were never installed and are still in their original packaging as pictured. If you are looking to make power and don't want to worry about your engine, this is the way to go.
Crower Rods:
the strongest yet lightest rods available. While other manufacturers are cutting corners, Crower incorporates only the finest aircraft quality steel. Every contour is designed to enhance overall strength and reliability at high engine rpm. Crower connecting rods incorporate an I-beam design that eliminates pockets of excess material and delivers exceptional longitudinal and horizontal strength. The cap screw design assures true roundness and a positive bearing seat under severe load factors, in which eliminating rod bearing failure.
Protect your investment by insisting on only genuine Crower rods for your high performance needs.
From https://www.raceeng.com/p-23780-crower-billet-rodmazda-protege-20-set-b93787b-4.aspx
New on sale for $1,001
Wiseco Pistons:
Wiseco Sport Compact Pistons are made from dedicated forgings produced in-house to give you a light weight piston with superior strength and optimal design. Being the multivalve piston technology leader, the line features specially designed valve pockets, complex dome and crown shapes, the steel nitride/napier xx rings and optimized skirt profiles. The pistons come standard with our ArmorGlide coating material for reduced friction and noise, freeing up horsepower.
From http://www.importperformanceparts.net/imports/wisecopistons_mazda.html
These are stock mazdaspeed compression (9.0:1) and drop in.
New on sale for $537
I also have the rings for the piston which are $50 new.
Total new costs $1434
I am asking 1200 shipped.
Again, all parts are brand new and never opened, this is your chance to get exactly what you need to build your engine, make more power and save a couple hundred in the process.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Crower Rods:
Wiseco Pistons:
