My car as begun to stall after i shift under boost, and coast. i thought a bad vacuum could have been the issue but ive checked and double checked them, to me this problem seems like one someone with a bov would have if not set up properly. but after every shift the bpv dumps the charge back into the intake system after the maf, which mine is doing, and like i said this is a new problem with no physical changes to the car from before. I can easily make this happen by just drivng up to 5000rpm in second shfting into third and letting off the gas completly and the car will die, but if i give any throtle input it is fine. I city drive quite a bit, so i coast quite a bit, and latily have been stalling qute alot. i need help!
