After 2 years in the making of this turbo kit, I have finally decided to sell it as I’m likely going to be selling my MP3 very soon. The idea of this kit was to make 180-200whp easily on stock boost and be reliable as well for a DD. Nothing was spared going into this kit. Everything is brand new minus the manifold/turbo/s and j-pipes and Ecu.
OEM MSP unflashed ECU
OEM Callaway MSP Manifold(2-3 runner may have been cracked. didnt take a chance and got it welded anyways. Relief cuts have been made to the manifold. can included a spare uncracked manifold as well)
Nissan SR20 T25 .64a/r turbo(fresh rebuild with 0km on it and clocked properly
New ATP MSP 6-8psi wastegate w/MSP wastegate bracket and Vibrant silicone hose
Corksport 2.5" SS S-pipe(rare)
Corksport 2.5" SS J-pipe(rare)
ATP 1.8 NPT to 4AN turbo fitting
ATP 4AN to 4AN 45degree swivel fitting
ATP 4AN 36" braided teflon feed fitting
ATP 4AN to 1/8NPT filtered fitting
ATP 1/8NPT to 1/8NPT .065 Restrictor fitting
Prosport Blue M20x1.5 Oil Sandwich plate
ATP 10AN threaded T25 drain fitting
ATP 10AN 12” braided Teflon drain fitting
ATP 45” 10AN to 1/2NPT fitting
Vibrant 1/2NPT threaded bung
New FS-DE Oil Pan
ATP 3/8” barb coolant fittings with banjo bolts
ATP 2 bolt 2.5” Compressor inlet adapter
ATP 3 bolt 2” compressor outlet adapter
ATP 4ply 2” to 2.5” 90degree coupler
ATP T25 gasket
ATP T25/28 5 bolt outlet gasket
ATP T25 drain gasket
New Mazda Exhaust Manifold gasket
New Mazda S to J pipe gasket
ATP copper lock nuts for manifold to turbo and turbo to s-pipe
ATP grade 8 allen bolts for every adapter
AEM 2.5” dryflow Cone filter
CX Racing 28x7x2.5 Intercooler kit with 2.5” aluminum piping, silicone couplers and t-clamps
Blitz Old school BOV w/Velosity stack(Loud!)
Prosport white/blue mechanical boost gauge
Prosport white/blue electronic oil pressure gauge
Prosport white/blue air/fuel gauge
The kit is basically fully assembled and ready to go. It only needs the 1/2NPT bung to be welded to the oil pan , get 2 feet of 3/8” hose for the coolant lines and get the BOV bung welded onto the IC pipes. Other than that this kit is all ready, pre-assembled and torqued
Looking to get $1600 for everything. Located near Toronto Canada. Willing to ship or meet over the border in New York state.
New FS-DE Oil Pan
ATP T25 gasket
