Bored with looks/ Opinions anyone?
Idk about everyone else but i have been really into the concave wheel look.
Im gonna do my best to fit some 17x9's/ 17x9.5....Stretched with a finder roll/ flare/ camber I'll make em fit.
Just gotta figure out what wheels i wanna use. im leaning more torwards some grids.
What do you all think? what do you think would look best on my p5 out of these 3 Rotas?
Rota Grid:
Rota P45R:
Rota Torque:
Rota Grid
17x9 +25
17x9.5 +30 with a 10 mm spacer.
205/40's all the way around.
It'll fit for sure.
I have always been partial to 5 spoke rims, so either of those. Good luck getting these to fit.
you guys think i could pull off 17x9.5 all around? the 9.5 is a lot more concaved then the 9..so it looks.
even if im going to TRY and pull it off anways.
Yes, you could. Front would be even easier. Only thing I'd be worried about is contact with the frame at full lock, should be to bad tho.
i also need to know where to get camber bolts that allow more then -1.75 to -3 degrees or just how to go further.
i have 0 to 1.75 bolts in the front.
What can I do to just simply get more negative camber?
Slot the struts, gain as much camber as you want. Your gonna need around 4 degrees in the front and 7 in the rear. Crazy pull/flair. Maybe a pull in the front.
