Sir Nuke said:NOPE...not here...not even stink....
I am sure you are aware that BLUE SMOKE is NOT good.....as that is what you get when you are burning oil....did it stop pretty quickly? or did it continue to do it? if it stopped pretty quick...that is an indication that your valve stem seals are leaking.....just a small amount of oil runs down the valve stems then gets burnt off when you first start up the car....when things heat back up they seal up...sometimes...and because of the motion of the valves and the fact that the exhaust side is presurized, it minimizes the amount of oil leaking past the seals after starting the car....thus the smoke stops as soon as all that has leaked has burnt off. Just something to keep in mind.
derrick1623 said:hey manuel...what you don't believe that is the case, or...?
hey nuke...it shot out like a two-three foot blue smoke puff, then a small one then it was fine, but it was definately blue smoke, and i think i even said, dood ur burning oil!.
