Accessport on a stock Speed3
Mazdaspeed 3 Tech Pkg
I'm new to the Mazda family and I want to know if I get a accessport for the first mod what can I expect? Thanks for the help guys.
You will see some small gains, I would suggest the following:
Intake Change - let it breathe, many options here
Fuel pump internals change out - keep the pressure up, a few options
Then the AP
Then move into fixing the exhaust, fixing the IC and alot other items.
Enjoy the journey
Z
I suggest getting a stiffer rear motor mount as your first mod (will make shifting much smoother and lessen engine movement), then Intake and TIP, then Fuel Pump Internals, COBB AP, then Downpipe or testpipe/2nd cat delete. This will allow you to run the sucky Stage 2 OTS MAPS. At this point you can really start tooning your car.
Latest posts
