I tripped the ABS and brake lights, so I ran the codes and got 14 and 48. Pulled the LR sensor, cleaned it, which got rid of the 48 code, but not the 14.
I have never seen only one code go through (usually they're in pairs for each corner). Any ideas on what might be causing the 14 to stick around? I've cleaned all connections, fluid is topped off and tight, never any leaks in the system. Thanks in advance.
