Hello, I have a 2007 CX7. I can start it. It will run for a little while but when I put it in gear it will die but after I do that, it will not start back up. It tries but doesn't start. I replaced the fuse for the injectors. I'm not getting any codes either but the TSC light is on. The car has around 107,000 miles. I did replace the bypass valve L3K9-20-2 50A as the vacuum nipple was broke. I haven't had the car very long and bought it at auction.
Any advice would be greatly appreciated.
Thanks
Jeff
Thanks
Jeff
