I have just completed removing and replacing the engine on my 2006 5. Now the transmission is not working properly.
Symptoms:
- I have to rev it up a bit before it engages in reverse.
- while reversing, it will engage and disengage unless I get on the throttle fairly firmly...then it will fully engage
- it needs to revved up a bit less to go forward
- it will get around in 1 and 2nd in "manual" mode (its an auto)
- if I try to use 3rd or 4th, it really slips/revs
notes:
- ATF is full (MV grade/spec) - was all drained when I re-re'd the motor
- might be a bit too full, but I am a bit unsure to honest
- torque converter came off when the motor and tranny were split (I am fairly sure it was put back in place where it should be)
- tranny has 185k on it (it was working fine before the motor swap)
thoughts:
should I try dropping the ATF and replacing the filter to see what happens?
Thats what I know...I am really trying to avoid having to remove it again if I can help it. Any advice would be very much appreciated. I have been combing the net looking for info on this, but nothing so far.
Symptoms:
notes:
thoughts:
