2003 Protoge - Cranks but won't start
Eric1234
2003 Protoge
I was driving on the highway and had my radiator spring a leak. Had to have the car towed home.
Replaced the radiator and now the car won't start.
Can smell gas in the exhaust so I believe its getting fuel. Will check using timing light to see if coils are working.
Has anyone ran into this same problem ? Any help would be great !!!!
Eric
I forgot to mention that the leak was near the radiator cap neck, so water sprayed onto the engine.
I replaced one of the ignition coil packs, the one over cylinder #2. But this didn't fix the problem. Have spark ( used timing light ) from the coil pack over cylinder #3, but nothing from the other coil pack.
Does anyone have the pinout for the connectors that plug into the coil packs and what the readings should be on each pin with ignition ON and OFF ?
Help !!!
