I have a 2003.5 mazdaspeed protege turbo fs 5500 obo.
reason for selling is I need a bigger vehicle for my growing family.
you can look up other information here with pictures
http://charlotte.craigslist.org/cto/4490559709.html
production number 575 Silver
interior 8/10
Exterior 8/10
The good.
New head new valve seals.
Arp head studs
3 angle valve job
Water pump
Timing belt
Crankshaft seal
Cam seals.
Vc gasket
Plugs wires and ignition coils
new front and rear brakes
rear sway bar relocation brackets
The bad.
There is a minor oil leak and I can not figure out where it's coming from.
I also have a extra head with cams and dowel pins being redone as we speak.
Everything is stock other than prosport Evo series 60 mm wideband and 52mm boost Guage. It's sits in the bezel that I had made for me.
interior 8/10
Exterior 8/10
The good.
Arp head studs
3 angle valve job
Water pump
Timing belt
Crankshaft seal
Cam seals.
Vc gasket
The bad.
