hackintheback
- 08 Speed3
So, I just purchased a set of 17x9 +48 with some 245/45's mounted.
I had done a lot of reading and I found that gen1 MS3's were able to clear the above setup with a 5mm spacer up front to clear the spring perch on coilovers(which I have) with some light rolling necessary.
However, when trying to install them today, I was rubbing against the spring perch very badly. I stacked up some spacers I had and even with ~13mm of spacing I was STILL hitting the god damn spring perch..
So I am looking for ideas as to why my situation is so..'special' ?
I am trying to avoid having to run ~18mm of spacing up front and some stupid camber. This is a track oriented setup so I can't have some crazy camber going on..Also, to note the rears fit perfectly fine!
I've already confirmed that the rims are indeed +48
Any tips are appreciated.
