TrilogyBPM
- 2001 Mazda Protege ES
hello all i have an 01 es and its giving me a hard time...
sporadic idle, boucnes between 800-1500 rpm at times sometimes it jumps from about 400-1000....
sometimes it cranks and wont start sometimes it will just start and stall.
when it does run its barely driveable it will run like poo spitting sputtering and voilently shaking till it hits about 3k rpm then it runs like normal.
i have several videos of it on my youtube page bpm03 check them out and see what you think, ill also post one to this thread...
now heres everything ive replaced or done in an effort to fix this..
tps
maf
knock sensor
timing belt
fuel pump
fuel strainer
fpr
cam sensor
crank sensor
cleaned egr valve
cleaner iac
cleaned throttle body
deleted both cats
replaced intake tube
plugs
wires
ignition coils
and ive probably replaced even more lol heres one video of it running i know its night and you cant see it shake violently but you can hear my motor mounts juttering around.
https://www.youtube.com/watch?v=K9_vem_ACss
tps
maf
knock sensor
timing belt
fuel pump
fuel strainer
fpr
cam sensor
crank sensor
cleaned egr valve
cleaner iac
deleted both cats
plugs
wires
ignition coils
