UPDATE AGAIN!!
Here is the dyno result, boost increased from 9 psi to 17+ psi with the built engine.
The torque translated to ft-lb is about 280 ft-lb, wheel power is 225 HP. The top graph is at 17psi, the lower graph is at 14.7 psi (as my HKS EVC has 2 boost settings)
My tuner asked me if I wanted to increase the boost past 17 psi, I said no, on the road the torque steer is enough to get me into trouble if I'm not careful. At third gear at full boost, my car veered halfway into the next lane with me fighting the steering.
Comments welcome!
UPDATE!!
I finally installed my forged pistons and billet rods. Using JE pistons meant for the B6 engine:
The top of the pistons had to skimmed off to fit the ZM engine block
Here are my billet con rods (for the B6 and BP engine, same rod). These are more or less the same as Eagle H-beam rods or the Belfab racing.
My head (which is port and polished) will be fitted and the engine will go in within these couple of days. Will be changing my turbo (from a TD04L) to a IHI VF28 ball bearing unit.
Will need about 3000 miles or so to break in the new engine, then I'll keep everyone posted on the numbers when I retune the car.
Finally finished..........
Setup:
Hiboost IHI turbo manifold + downpipe
Forrester TF035 turbocharger
Precision 350HP intercooler
GFB bypass/plump-back valve
GFB manual boost controller
NRG fuel pressure regulator
2 SPAL fans mounted infront of the radiator (noisy!!)
310cc Toyota Supra injectors
Emanage with Greddy pressure (MAP) sensor + injector harness
hoses, lines, clamps etc etc
Currently tuned for max boost of 8 psi
Dyno results: SAE corrected 156 WHP, max torque 26 kg/m at 3500 rpm (about 188 ft/lb)
Car runs well, a little lag but bearable. Only issues left to resolve:
- rather rough idling. MAF sensor too close to the open pod filter
- Clutch. Still stock, looking to get ACT disc.
- exhaust. Currently running 2 inch but stock muffler. Changing to Magnaflow
Comments welcomed!
Comments welcome!
UPDATE!!
Setup:
Comments welcomed!
