TheMAN said:
You are in school (and so am I as well as many others) for one very simple purpose: to learn. If you fail to accomplish that task and just simply get homework grades and barely passing tests (or failing miserably... either way, it's bad), then you have failed to accomplish that purpose.
Don't take this the wrong way, I'm simply trying to offer guidance so that you can try to learn stuff.
That's some funny s***. I went to school to get a degree. I have not used ANYTHING I learned in college in the real world.
I was the one who sat in back of the class, came in late, only did what was required to pass, finished the tests in 20 minutes, and still walked out with Bs and Cs. My degree still has the same amount of letters as everyone elses, and I did'nt make myself miserable doing it. I worked 3 jobs and played hockey while in school also.
I went to show that I can be taught, get a degree and then get a good job. I accomplished all of my goals within 1 week of graduation. I have moved jobs twice, both times for more money, and this week got another 14% raise. I'm currently in an Engineering Consultant position and moving into Project Consulting Management in a pharmaceutical clinical trials division. How 'bout them apples. (SLACKERS RULE!)
As was said before, college is about learning how to get information, not exactly what it is. It is also about building relationships and using them. You will learn, young ones.
Kat, you rock. If you need help, you won't find a better group to ask than here that I've found, just give us more warning next time.
Also, thanks for the tires. They helped out a ton! (through 2 sets now at 17k miles)
Later Kidz...
