Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: MPI: MAF-2-MAP conversion
  1. #1
    Registered Member igdrasil's Avatar
    12psi Protege5
    Join Date
    Sep 2002
    Location
    San Juan, Puerto Rico
    Posts
    4,087
    All updates will be ALSO posted in this 1st post
    This week I will be starting the MAF to MAP conversion. This means Im going to replace the MAF for a 2.5BAR MAP sensor. I know this involves a lot of tunning, first starting with logging voltages on both the MAF and the MAP.
    Im still on the brainstorming, trying to find the best way to log both sensors output at the same time, then work on the analog map to do the necesary corrections so the MPI output thru the MAP matches the stock MAF output.
    Any ideas, suggestions, comments are welcomed. good or bad, pros and cons, doesnt matter..all of em help.
    UPDATE JAN. 30, 2005 -CAR IS RUNNING WITH NO MAF!!!
    Idle is perfect, acceleration thru all the rpm band is great. Normal Driving is fantastic considering there is no tunning at all, only some numbers on the analog map. Some stumbling building boost, but the rest is smooth. And finally...no stalling issue so far, still need to vent the BOV more and see if its stalls or not
    Mods: Oliver Long Rods | CP 8.5:1 Pistons | Microtech LT10S | J&S Knock SafeGuard | HKS Intercooler Meter | Prosport Boost, EGT, OilPress Gauges | MSD RPM Switch w/ shiftlite | Car PC w/ OBDII scan ...etc
  2. #2
    P1kaChu Haz P4rts 4 yU0 Captain KRM P5's Avatar
    Donated: $15
    2002 BJFW, 2007 BK3P, 1979 SA22C, 2005 BK3P
    Join Date
    Apr 2002
    Location
    Grayslake, IL
    Posts
    20,504
    i think kooldino would be the person to ask on this subject, no? i only say this as i know he has done the change on his mpi
  3. #3
    12psi Protege5
    Join Date
    Sep 2002
    Location
    Posts
    4,087
    Quote Originally Posted by Captain KRM P5
    I dont know for sure...but I think he still have the MAF controlling stock injectors and MAP sensor for boost reference to control extra injector and ignition control.
  4. #4
    Unemployed Jerk StuttersC's Avatar
    2005 Mazda6 s
    Join Date
    Oct 2001
    Location
    Denver area, again
    Posts
    4,111
    Why are you switching?
    '05 Mazda6 s ....
    "How do you value your what you contribute of to add work force? And, which do you most can't the least?"
  5. #5
    12psi Protege5
    Join Date
    Sep 2002
    Location
    Posts
    4,087
    Quote Originally Posted by StuttersC
    Couple of reasons.
    1. Tunning ability for up to 21psi on the 2.5BAR MAP
    2. Remove MAF restriction.
    3. BOV Stalling issue will be gone.
  6. #6
    101010 = 42 Micah's Avatar
    Join Date
    Feb 2003
    Location
    Beachwood, NJ
    Posts
    2,072
    that seems like a lot of work for decent results.
    Good luck. I think for most people it would be more economical to upgrade to the 80mm MAF. BOV's, on the one hand I think they are rice, but on the other - they do serve a purpose, I just hate the "ricer hard-on"'s that people get when they hear it vent to atmosphere. Admittedly, I myself (shame) admit it's pretty kewl sounding.
    Then again - up to 21psi...... good golly miss molly. I can't wait to see how things progress.
    Quote Originally Posted by bigbillsfan
    here's a response : you are a full fledged asshole.
    I broke 2nd gear on Saturday July 14th, read about it?
    "Yes, I am a inconsiderate bastard who thinks he is irreprehensible. If you think that I should feel remorse then you simply don't grasp the concept of who/what I am." - me
    Black 2002 Subaru Impreza WRX 6-speed (vf34 - daily driver)94k mi.mod list
    10/08/2006 - 14.089@103.01 (First time at the track. Guess who needs to learn how to launch?)
    2002 Chevrolet Corvette Z06 43k
    Escort Solo S2 Cordless Radar Detector
  7. #7
    Registered Member Fast lane's Avatar
    2003.5 Mazdaspeed - Laser blue
    Join Date
    Nov 2003
    Location
    Lincoln Park,New Jersey
    Posts
    509
    I think you should just run the 80mm MAF(its massive) and screw the atmoshphere bov and just recirculate...
  8. #8
    Transmission Destroyer Focus's Avatar
    MSP and RX-7
    Join Date
    Oct 2003
    Location
    Montreal
    Posts
    2,602
    Quote Originally Posted by igdrasil
    You can use something like the Innovate LM-1 with the AUX cable and log up to 6 inputs at the same time, up to 44 mins.
  9. #9
    12psi Protege5
    Join Date
    Sep 2002
    Location
    Posts
    4,087
    Update Jan. 30, 2005
    CAR IS RUNNING WITH NO MAF!!! (placed on my backseat)
    Idle is perfect, acceleration without load thru all the rpm band is great. I would love to take a video but my cam is dead.
  10. #10
    MSP and RX-7
    Join Date
    Oct 2003
    Location
    Montreal
    Posts
    2,602
    A How-To would be nice to read.
  11. #11
    yes, yes i do. dominoy2k1's Avatar
    Donated: $20
    02 1500 4x4, mp3
    Join Date
    Dec 2001
    Location
    houston, tx
    Posts
    4,920
    Quote Originally Posted by Focus
    Adam i will never forget you buddy...
  12. #12
    12psi Protege5
    Join Date
    Sep 2002
    Location
    Posts
    4,087
    Update...this is anyway a PM i sent to focus:
    Its very very very easy to at least start the car and make it idle.
    The fun starts as you go into 0 vac.
    I found the best way to do this (if you can handle issues) is to 1st start the car with the MAP and make it idle having the MAF only connected to the EngTemp wire and monitor BOTH the Analog Output and EngTemp voltage.
    Normally when the car Idles the MAF is sending about 1.9v-2.2v, the map will send about .30v-.80v so you just have to rise the fuel zero calibration to XX number, until itl sends around 2.0v-2.4v out of the map voltage on idle.
    Now having the car idle fine, the fun part starts. Now we separate men from children. Its not easy, but its fun and a challenge.
    The easiest way is to monitor both voltages on the graph and try to keep both drawings nearly equal, to mimic each other. I will post a pic in a few minutes and a log file.
  13. #13
    12psi Protege5
    Join Date
    Sep 2002
    Location
    Posts
    4,087
    This is how it looks
    Check this...you will see the voltages differences, this is how it will start, you need to get both lines nearly identical, check voltages at the left corner, this is what you most likely want to see all the time (refering to voltage, notice the green bar) unless you want to do corrections when you want to behave different. If you want near stock feel, both lines should mimic one other:
    More of the same, you need to correct these peaks, differences:
    Getting better:
    And better....
  14. #14
    I Too Be Wit The Darkside KzA's Avatar
    2001 Yellow Protege Mp3-T
    Join Date
    Aug 2002
    Location
    Toms River, NJ
    Posts
    1,857
    WOW...that sensor readout is nothing short of SICK...Good work man damn...Im Impressed
    It would really be appreciated if you wrote something up on this..like a REAL good writeup going into the tuning alterations that have to be made..Then we could put it in the MPI Library Sticky so all of us could use it...
    Please?
    -Joe
    2001 Yellow Mp3
  15. #15
    MOTM Winner Jan '09 Kooldino's Avatar
    Donated: $20
    Authorized Vendor
    MP3
    Join Date
    Oct 2001
    Location
    New Jersey
    Posts
    11,646
    Yeah, that's how I'm set up. Why are you switching to all MAP? I thought you were happy with the MAF setup?
    Vivid Yellow MP3 - SpeedCircuit Turbo Kit @ 14-19 psi - SpeedCircuit forged motor - SpeedCircuit built trans with PAR gears & M-FactoryLSD - and FAR too many mods to list. 13.3 @ 108 - 18psi on the T3 in 2005
    Be sure to check out SpeedCircuit on facebook!
    Pope MSP Turbo Manifolds on sale now!
Similar Threads
  1. MAF limit reached @ 14psi
    By Kooldino in forum Mazda How-To
    Last Post: 02-07-2005, 07:12 PM
  2. CEL code, need some help
    By ^tyrant^ in forum Mazdaspeed Protege
    Last Post: 09-22-2004, 02:26 PM
  3. engine management
    By tyusha in forum Mazda Protege
    Last Post: 01-21-2004, 12:34 AM
  4. MAF vs. MAP
    By DBR in forum Mazda How-To
    Last Post: 10-07-2003, 10:20 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
