Well, it arrived this morning around 10 A.M. overnight from Columbia. Let the games begin. Came with a 3 BAR MAP sensor, Boost controller option, Wideband option (for closed loop), and the pre-map to tune off of.
Thanks to Juan for the speedy delivery, and support. (thumb)
E6X Kit:
Water Temp Sensor Adapter:
Harness Connector:
Boost Controller and Control Solenoid:
Air Temp Correction Sensor:
I'm going to go ahead and try the RX-7 S5 (non-turbo) 460cc injectors:
Since they are a little bigger, I would just have to pull out a little fuel across the whole map.
E6X Kit:
Harness Connector:
