Alternative MAFs
xenosilvia
Kouki S14
Since our MAF's are maxed out at around 250whp, I'm looking for the best alternative to use, obviously with a EMS.
-GM 3Bar MAF
-Cobra MAF
-Z32 MAF
If anyone knows the voltage ranges that'd be great....
-mx3ownzj00
If you replace the MAF, you will need something to control it because the stocker is designed to work the the pretege ECU. I have an 80mm PRO-M MAF that I used with the MPI tuner. I had some issues when I used it, but that was a long time ago when I had other issues. MPNick uses it and it works fine, he was able to get in the 300+whp range with it. I anticipate him getting close to the 400whp soon.
I think the FCD clamps the MAF voltage so you don't have to worry about it, but I don't know much about the FCD.
I think the pro m 80mm is good for about 450hp Nick said...its huge, and i will hopefully be pushng 400whp with this set up shortly...
Lightning 90mm MAF. Very repeatable and accurate. Well known calibration and curve. HUGE HORSEPOWER POTENTIAL!!!!
btw, THE pRO-m 80 mm IS CAPABLE OF MUCH MORE THAN 450HP. NMRA Renegade Mustangs are restricted to 80mm MAF and they make over 900whp. It's all about tuning to keep the voltage below 5volts.
I would PM Mpnick he sells them for the protege to be used with his mpi tuner.
mx3ownzj00 said:
I'll have to look into the ProM 800, anyone know the price off hand?
Yea, I was just wondering. If I buy a shortblock it'll be from Nick so I'll discuss MAF options then.
I will NOT be touching FCD's :)
If I needed a MAF right now I would but I'm just researching my options before I build the motor and tune the stock turbo to hell and back. I don't think Focus is running a different MAF and he's making more than Kooldino. I'm still wondering why.
I know I've seen 3rd gens with 2-3different numbers on their MAFs but no one had confirmed that those numbers correspond to different parts. I guess some are lucky with more forgiving MAFs and some aren't.
The tuning method!!!:D Sorry Kool, I had to!(thumb)
LOL, I guess I'll be the first to find out how well the Unichip tunes for big numbers in comparison to the MPI SMT6 and eManage. Hopefully I can get away with using the stock MAF for awhile :)
Its cool, I knew what you meant, even though I didn't type it correctly. I was researching last week ans they seem like darn good units.
