Here are my contributions thus far... the "Last Microtech Maps" was the last screen shots i took of the car when i had her in.... this is with stock injectors and headers. the car ran pretty good with it like this.
the "Microtech Pics" zip is EVERYTHING ive done with the microtech. it shows data logging, map pics, everything. the files are kind of big but who cares.. download them to see what you can get...
i know steve and dave are gonna come out with some crazy turbo sheit with 550cc injectors and some crazy turbo sheit... a month or two more and this thread should be filled with lots of good sheit!
I'm adding all of our install manuals and documents here, check the next several posts of my screenname to get all of the documents! As always, use at your own risk, every engine is different and no map is truly universal. Be CAREFUL and Enjoy!!! (updated 1/10/13)
550CC base map for up to 5,000 rpm's (break in period).
hey, i'm gonna try and start with your timing map on megasquirt. are the values on the first row of the chart pressure values> as in vacuum, to atm., to boost? Many thanks, steve.
-Mateo
column A is rpm... row 2 is vacuum... row 3 is vacuum correction factors, and Column B is raw unadjusted timing based on rpm... then the rest of the cells are a combination of the raw timing (column B) paired with the correction values (Row 3).
The "improvedstockinjectorbase" will be good... in the next week or two I'll have a new one to replace that which is from an MSP with light mods and stock injectors that will be very close off the bat.
Perfect timing, should be getting my Microtech by then..good to know I'll be able to start my car off the bat--I was in way over my head with Megasquirt heh.
cool! You getting your LT8S through Protege Garage? or you buying it through me or buying the used one that is available? (I'm not putting the screenname together with a name)
