(reposting this here from another
thread) I have decided to go blue with mine also. I have tried messing with the gauge face plate as well to see if I can get a custom scheme with all the idiot lights to. I hate the superbright green of the CRUISE light, for one.
I am changing the bulbs in my gauge cluster too. I was able to get the speedometer and tach needles off fine. I undid the screws first, then pulled the servo off the back, instead of pulling the needles off the front. However, the small gauges appear to be a lot more fragile, and I broke the fuel gauge. I ordered a replacement cluster on car-part.com. I didn't have to take off the temp gauge to do my mod...
Since mine is a 99, mine are all green. I was able to sand off all of the green backing around the numbers to leave them white in preparation for the new blue led's I am putting in.
You could then potentially leave all the white bulbs in and paint the numbers, leaving the option to you to completely customize your color scheme. I did some tests on a two-tone scheme, and changed my mind; however, some normal Testor's paint from any store that sells plastic models will work just fine. Be sure to buy some thinner too in case you don't like what you see.
NOTE: Use 400 grit or higher for the sanding. You can use a fine-point set of pliers to pop out the needle posts. You can see it in the tool pic below.
These are all 600x450
Pics with the gauges already sanded:
Broken Gauge- you can see its the pin that broke, not the needle itself. I am now using that needle for experimentation to see if I can get a different needle color, too.
Speedometer -
Back Front Against the light:
Tachometer -
Back front
My Custom Fine Point Sanding "
Tool
Fuel and Temp -
Back Front
My Two-Tone
test - keep in mind this was after the first pass with the brush, so the blue looks a little inconsistent.
