- MP5T / 944
They are a bit of a b****.... Worth the time however.
I have never had a leak from any of them..
JCell said:good to know, this how to came very handy when purchasing my lines
thanks brian
Brian MP5T said:Dude, You Do Not want to buy that part... The tap is like $100
Just borrow it from a local shop or have them do it..
The drill comes with the tap...
djarkitek said:i broke the tap going into the back of my block off doing this...lesson? never over torque >.<
CrazyCaker said:Why were you tapping the back of the block? The MBSP (Main Bearing Support Plate) is aluminum, you should have no problems drilling it and tapping it. I did mine while it was still on the car. I used an angle drill and a 22/32" bit which had it's shank reduced to fit the chuck of the angle drill. Tapping the hole 1/2" NPT using a t-handle was the easy part.
