HOW TO - Turbo Oil Lines
man.. you're all so impatient :p
it'll be hosted on ottawaprotege.com once i get my linux box up and running :)
so i'm assuming that what I made is what you wanted?
i kept the BG colour from here.. just to make it a little more 'professional' looking.
BUMP: Here is an UPDATE....
The Tap for the Aeroquip fitting is a 1/2 14 NPT Pipe Tap...
not on mine. you might have to be logged on for all to see. or maybe my computer sucks balls. either or.
old thread... But would it be possible to just grab the windage tray assembly from an MSP? If I have all of the stock lines, it'll be a direct fit, correct?
Have you considered using a stainless steel adapter that goes into the block?
Brian MP5T said:
Get the fitting that fits the 1/8" Hole to an AN-4 Hose Fitting.
I thought that the back of the block used a 1/8 BSPT thread, and that the standard 1/8th NPT fitting would not fit this thread...
can you point me to exactly what adapter/fitting i need? thanks!
