Page 1 of 60 1231151 ... LastLast
Results 1 to 15 of 896
Thread: MP5T Rebuild Photo Journal
  1. #1
    Banned Brian MP5T's Avatar
    Donated: $5
    MP5T / 944
    Join Date
    Jul 2003
    Location
    Ottawa Ontario
    Posts
    10,882
    I'm starting this thread to document the rebuild of the MP5T in a cleaner way than the Boom thread which is up to over 20 Pages. I'm going to reserve 10 or so posts near the beginning. Each will have another step in the process until the rebuild. Please feel free to post questions or discussion after the 10 Reserved.
    The Critical Failure... (boom06)
  2. #2
    Donated: $5
    MP5T / 944
    Join Date
    Jul 2003
    Location
    Ottawa Ontario
    Posts
    10,882
    On the 14th Of November, A FS-20 was dropped off in my backyard. It is out of a 2003 P5 that was rear ended at 51,000Km. It came as you can see from Valve cover to Oil Pan, what a steal at $900.00 CDN!
    http://www.car-part.com/
    Special thanks to YP5TO (Jason) for helping me with this link!
  3. #3
    Donated: $5
    MP5T / 944
    Join Date
    Jul 2003
    Location
    Ottawa Ontario
    Posts
    10,882
    (PISTONS FROM BEAU!!!)
    Stock Length Rods with 8.5:1 CP pistons...
    ARP STUDS
    Copper Gasket
    Jesus.. I Wonder which one is the new one?
    The New Hotness!
    Old And Busted!
    Ladies and Gentelmen! I give you ARP Head Studs. Possibly the best Studs in the World, If anyting will hold the head together.... This is It. 80 Ft/Lb is the torque for those who might do this in the fututre...
  4. #4
    Donated: $5
    MP5T / 944
    Join Date
    Jul 2003
    Location
    Ottawa Ontario
    Posts
    10,882
    (Crank Balancing)
    Feb 14th is the day. The engine is off the stand and upstairs, the Manifold, Head, Cams, Lifters, Pistons, Rods, Bearings. SHIT. It's all in three boxes ready for Monday..
    I'm heading to renfrew for...Deck, Head, Alignhoning, Extrudehoneing & Port, Crank Balance, De-Glaze, Assembley.
    Feb 15th Today the Engine Was Tanked and the Deck Was brought level again.
    The Pistons are going to be placed in the cylinder to check for clearance. If there is too much room, the pistons are being sent to Toronto that day to get 2 Thou of ceramic coating added to the piston head and skirt.
    The Boys at Renco are used to much larger engines. He was surprised that the whole thing could be picked up by one person (Me), they had the hoist and everything... Oh, well, I hope this starts a new line of possibel work for this big block wonder shop. They smiled when they saw how small the pistons were and then giggled when the remembered that there were only 4 of them.
  5. #5
    Donated: $5
    MP5T / 944
    Join Date
    Jul 2003
    Location
    Ottawa Ontario
    Posts
    10,882
    (Engine Assembley)
  6. #6
    Donated: $5
    MP5T / 944
    Join Date
    Jul 2003
    Location
    Ottawa Ontario
    Posts
    10,882
    (Drivers Side A Pillar)
    Parts Arrived, the second Double pod is going above the first one, then the entire pillar is being bondoed and sanded down, primed, painted whit and clear coated, just like the last one. The Guys at Terry's Collision in Pembroke will be painting it along with the CF Hood. I don't have the skills to do it the way it should be done.
    Got it all together... I guess it really is that high up...
    I got the Manifold Back after getting the EGT Probe welded in the collector. The Header wrap was ordered in Black this time and the Proper Stainless Steel DEI Straps came in just today. Here are some Pictures of the Manifold with the Wraping and the manifold when it was new...
    Just as a Note. I also picked up a set of Sparco seats from a Fellow Toronto Protege Forum member.. SWEET!
    Got the Wiring Done and the seats in today!!
    Here is a picture of the Tinting as well...
  7. #7
    Donated: $5
    MP5T / 944
    Join Date
    Jul 2003
    Location
    Ottawa Ontario
    Posts
    10,882
    (Parts From Tony at AWR)
    Here are some Pictures of the Prototype Protege 5 Triple Pass T6 Aluminium Radiator. The first picture is just that, the second one is for anyone who does not really know what Triple Pass means...
    Rather than one big rad core, the coolant is forced to pass down 1/3rd of the core, up the middle 1/3rd and then down the last 1/3rd to the outlet. Normally a radiator is much hotter in the middle between the two connections and the sides are rather "UNUSED".
    Path of least resistance would let the hot coolant flow directly as possible, This rad forces the coolant to travel the entire surface area of the radiator, plus the radiators design is much more effecient. The end result is much more consistent temperature, much better ability to remove excess heat from the coolant and yes a slightly higher pressure rating to allow the temp to get higher without boiling.
    More Stuff From AWR came also. The Famous 21mm anti sway bar with adjustable end links front and rear, but I also picked up his stiffer trailing arm for the Protege. As you can see it's alot stronger than the stock one, plus it has Poly-U inserts to geep everything aligned during cornering. Result, A Rock solid rear end. All That plus the Tein-ss should make the car like a giant Go-Kart!
    Thanks for your help Maclum! The Job of rear suspension is done... 2 Hours from start to finish and no unexpected problems...
    Here is the new "Firm Planted" Rear end for MP5T...
  8. #8
    Donated: $5
    MP5T / 944
    Join Date
    Jul 2003
    Location
    Ottawa Ontario
    Posts
    10,882
    (Hood Stuff!)
    Here is what the hood looks like when it's made...
    Extractor Hood Almost Done! It's being painted white with the exception of 1" by where the windshield is...To Avoid that ghetto look of a black hood on a white car...
    The CF Hood, A-Pillar etc are all painted white to match the car...
    IMO CF is Ghetto on a White car...
    Im Picking up The Hood Today (DONE)
    Ok, Carbon with 4 Layers of White, 4 Layers of Clear.
    MS In Carbon and a 1" Strip near the Window.. ENJOY.. I will.
  9. #9
    Donated: $5
    MP5T / 944
    Join Date
    Jul 2003
    Location
    Ottawa Ontario
    Posts
    10,882
    (VALVE COVER STUFF)
    It's really quite minor and has not much to do with the "REBUILD" but, detail under the hood is what I'm working on as the engine is completely apart and I'm waiting on parts to continue...
    Valve Cover and Intake Manifold are being polished on the outside then the intake manifold is going away for a week to get Extrudehoned. Here is the new bolts...
    These were taken before the writing was removed...
    After removal... Still a work in progress...
  10. #10
    Donated: $5
    MP5T / 944
    Join Date
    Jul 2003
    Location
    Ottawa Ontario
    Posts
    10,882
    (Timing)
    TRI-POINT Adjustable Cam Gears...
    The One on the Left has been polished. It's steel and looks alot better in person than the picture...It took about 3 Hours as it's Steel...
  11. #11
    Donated: $5
    MP5T / 944
    Join Date
    Jul 2003
    Location
    Ottawa Ontario
    Posts
    10,882
    UPDATE!!
    It's 7 am and this is how the day is starting...
    FMIC and Hardpipes, CF Hood Fitment (4 Hr, GD APC!!!) and the inner fender plastic shit. Then drop it off the hoists. Zoom!
  12. #12
    EvilMSP EvilMSP's Avatar
    2003 Black Mica MazdaSpeed
    Join Date
    Sep 2003
    Location
    Placentia, Ca
    Posts
    969
    Nothing you feel like changing in the valve train?? I have never done an engine rebuild but I'm just curious about why you arn't touching anything in that area.
    Mazdaspeed #666(flame)
  13. #13
    Donated: $5
    MP5T / 944
    Join Date
    Jul 2003
    Location
    Ottawa Ontario
    Posts
    10,882
    Quote Originally Posted by EvilMSP
    The valve train is rock solid for what I'm planning for this car. As long as the fuel management stays balanced, it will push 20Psi. I'm not planning to go that high, I want a really fast street car, not a really bare bones drag car...
  14. #14
    JDM Rainbow L8R's Avatar
    Donated: $8.08
    02' Sport 20/Familia
    Join Date
    Feb 2003
    Location
    Honolulu Hawaii
    Posts
    8,715
    hmm good luck to you and your project
    cant wait to see all the developments
    Former Mazda Owner
  15. #15
    Donated: $5
    MP5T / 944
    Join Date
    Jul 2003
    Location
    Ottawa Ontario
    Posts
    10,882
    Quote Originally Posted by L8R
    Most of it will start in Two Weeks as that is when all the parts will be together.
Similar Threads
  1. Camel spiders!
    By 2words in forum Pics & Builds
    Last Post: 09-08-2005, 01:44 PM
  2. Replies: 16
    Last Post: 01-11-2004, 11:40 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
