**I think it would be great if we could post some diagrams or even get pictures of how you have your vacuum lines set up.**
Alright, I was trying to install everything this weekend, and I can't get it all to work properly. For one thing, my Autometer C2 boost gauge doesn't read accurately. I can rev the engine and it runs to about 10 PSI without ever moving. It sits at only about -10 PSI vacuum at idle. Also, when I shift about 8 PSI on the Greddy Profec B, the Autometer C2 is reading about 14-15 PSI, and my old manual boost gauge is only reading about 6-7 PSI. It is driving me insane. I will explain how I have it routed currently.
At first, I had a long vacuum hose running from the "brake booster" line, I guess it is called. This is the vacuum line on the top of the engine at the rear, closest to the firewall. I ran a T there, and ran it into my interior, where it split to another T immediately and ran into the C2 electronic boost module with a vacuum hose (as well as with the thin plastic tubing it came with, no difference with either hose), then it runs over to another T behind my center console, where it runs up to the Greddy vacuum filter then into the Profec B Spec II unit; finally, it runs from that T over to the Flying Miata FM clamp/O2 signal modifier (not wired up to the ECM yet). The other vacuum line runs down to the stock T, which splits to the Greddy boost controller valve, then down to the wastegate and over to the stock BPV (sold the hardpipes and HKS BOV).
So yeah, with this setup, my boost was holding fairly steadily, but the stumbling problem I have been having was there, feeling like a boost/vacuum leak. My gauges are obviously reading all differently also.
I switched this late last night, so everything is running off the same vacuum line now. I just pulled the hose that ran down to the wastegate, and moved the T over so everything is in-line. I was told by some people who have done some extreme turbo tuning that it is best to have everything run off of one vacuum line. My gauges still don't read accurately, and I am in fear of over-boosting. This morning on the way to work (5:30 in the bloody AM, cool air), Profec B was spiking to 8.5-8.7 PSI?!
I really need help. If people could post their vacuum diagrams, this could be a valuable resource, like the MPI and Profec B Spec II maps I have been creating Word documents to help tune with. I know others have problems with the C2 gauge not reading properly, so this would help a lot of people.
Thanks very much!!
Nic
nictlg7@yahoo.com
Thanks very much!!
Nic
nictlg7@yahoo.com
