twilightprotege
- 2001 323 Astina SP20 (P5)
Hi All,
well i should hopefully be getting my car back from the brake shop shortly after a bit of front brake massage.
i'm getting 2 peice rotors, 295mm x 25mm and i have series 5 rx7 4 pot calipers.
here's a pic (kinda dodgy looking) :
in the picture they are actually series 6 rotors, however the brake people decided to make the custom rotor hat a little too thin so the clearance behind the wheel was a little tight so they ground some of the caliper off. if you look carefully on the caliper you'll see a ring. well - that's where the brake fluid lines are. they ground too far off and when the applied the brake to check it's feel, POP! atleast the brake fluid went all over the car beside mine and not on my car (hehehehehe)
anyway, they are giving me the series 5 calipers for free.
will post better pictures when i get my car back (hopefully before the weekend). and i have to say, going from 258mm to 295mm rotors - man they look HUGE! and behind the stock wheel it looks even better!
