I dont think it would be easy. What would you do with the mass air flow sensor? You can out the forge bov/bpv on in place of the stock bpv.b00sted said:hey i was wonderin if it would be possible to just put a filter on the turbo inlet..and just take the whole intake pipe out..? is that possible? would there be stalling issues because it would eliminate the BPV?
Alright, You are wanting to remove the entire intake before the turbo and stick a filter on it? See Picture...b00sted said:hey i was wonderin if it would be possible to just put a filter on the turbo inlet..and just take the whole intake pipe out..? is that possible? would there be stalling issues because it would eliminate the BPV?
You need either a Blow off or By-Pass. No Debate.b00sted said:hey i was wonderin if it would be possible to just put a filter on the turbo inlet..and just take the whole intake pipe out..? is that possible? would there be stalling issues because it would eliminate the BPV?
