StreakinOraNgeX
- Mazdaspeed Protege 03
I saw this particular octane boost that said it will raise octane rating from 5-7 numbers, not points. Is this true or do all octane boosters only raise it a little?
jersey_emt said:The only 'real' octane boosters are xylene and tolulene.
celdridge said:Isn't tolulene paint thinner ?
jersey_emt said:Yup, and there's already some in your gas tank
Eeehhhhhhhhhh..... (shrug)celdridge said:ummm ... so thats why gas tastes sooo darn good .... mmmm mmmm ...
lol
The 'lead' in gasoline is tetraethyl lead, Pb(CH2CH3)4. When added to gasoline, particles of lead and lead oxide, PbO, are formed during combustion. This causes the gasoline to burn more slowly and smoothly preventing knock and raising the octane rating. 1,2-dibromoethane is also added to the gasoline to remove the lead from the cylinder by converting it to a vapor, PbBr2. This is how the lead gets released into the environment from leaded fuels.EvilMSP said:What raised the octane in old leaded gasoline? I don't wanna just assume it was lead additives alone so i'm asking
How do you knoe so much about all this stuff.... I wish I had that knowledge.goldstar said:Yes, Indy cars ( including Indy Racing League) use straight methanol fuel instead of gasoline. Methanol (wood alcohol) is similar to Ethanol (grain alcohol, typically made from corn) but it is poisonous to drink. At least with ethanol, if you lose the race you can siphon off some fuel, get drunk and feel better about the loss. (Don't actually try this!)
Methanol is used for two reasons:
1. Being less explosive than gasoline it is safer to handle at the track.
2. Since it is a "cooler" burning fuel with a higher octane rating than gasoline, it permits the use of much higher compression ratios without detonation than are possible with gasoline.
Both Methanol and Ethanol have a lower BTU content than gasoline so alcohol-fueled cars require larger fuel tanks (sometimes twice as large) and have a much higher fuel consumption compared with an equivalent gasoline- powered car.
Alcohol can burn with an invisible, smokeless flame compared with gasoline as you pointed out.
02 DX Millenium Red
