At least have some sort of supporting mods before you run higher boost, don't do it on a stock car. This isn't some bullet proof Supra engine that can run 30+psi; it's only a protege.jeffmsp said:i ran 9 when i was stock and the car ran like junk, sure it was quicker but thats not everything to having a good car. I stopped after I found coolant leaks all over the place, the stock exhaust is way too restictive and I guess the backpressure just hurts the motor more and more over time.
how many blow engines here were on less than 10# though?Bhamsan said:If you need proof, just go reading through some of the threads that talk about increasing boost, a/f rations, or blown engines, which there are quite a few of. If not, your proof will become evident in a couple years, if you still have the car in one piece then.
But then again, its your car. I have no real reason to be telling you lies so you can keep your car slow or anything, just trying to help you out. That is what this forum is about anyways. So right now you can believe me and take my word for it, or you can think I'm totally full of BS and run your car at higher boost until your heart is content. Just look at some of the other posts in this thread saying the same thing:
oh no argument there, you are using the product other than as the manufacturer designed - I just meant that IIRC most of the blown engines on here were way > #9 and in most of the MANY threads on this topic the prevalent seems to have been that 9# is rather "safe" provided you aren't dumping 85 octane on it or something.Rich24km said:Discreetspeed drove his car like he stole it with 14psi for almost a year. He blew his ring on the 4th cylinder. I ran 14 for a couple months. Everyones car is different running 9 "Shouldn't" hurt. But it definately can. If you have enough money to risk it go for it. If you're looking to make the car last then keep in mind that more boost kills motors no matter what you do if its stock, whether its 2 years from now or 2 weeks. Each car will do different things. All turbo'ed cars are different straight from the factory. Each has its ups and downs. I've gone back to stock boost keeping those things in mind i just wanted to know what the window i had to work with was. I run 7-8 psi sometimes and with race gas at the track 14psi. But without engine management and rods i'm not gonna be doing much with the boost knob anymore on the street. there haven't been that many blown engines. But there is a guy in raleigh that isn't on the boards that has blown his engine off 9psi but i think there was a little more to it than that.
