FC3s Boy said:what i do is take the foam part out and place it in a bag (big ziploc) i put a little gas in there and soak the filter for a min. or two, then just pull it out and wash it with water-
I take both parts of the foam and I just use reg gas in a bag, or you can use something like this as wellmushi said:The filter has 2 part. The top layer and bottom layer. Which foam part or you refering too FC3s boy? And also what do you mean by gas? Do you have to put any oil type substance after you wash with water?
FC3s Boy said:I take both parts of the foam and I just use reg gas in a bag, or you can use something like this as well
http://www.castrolusa.com/products/productpageo.asp?product_id=40&product_category=5
p5sundevil said:yes regular gasoline
p5sundevil said:there are many cleaners you could use, hell im sure you could buy the K&N cleaning kit and use it on the monsterflow filter...all it is is a solution to break down the gunk and dirt, regardless of the filter material.
p5sundevil said:lol tackifier...
